Post new topic Reply to topic  [ 11 posts ]
Author Message
Offline
 Post subject: banjo-bolt-round-head
PostPosted: Sat Aug 04, 2018 10:51 am
https://abingdonspares.com/products/ban ... ad-2-bolts
Hallo
now my fuel line is ok
new oil is in the engine
new spin on oil filter
new pressure line to the gauge
but i want to turn around the oil line from the block to the head
but at the block there ist a round banjo bolt and i dont know how to open it
a special tool available ?
moos internet says the hex one is only for the late TD and TF
_________________
Best Regards
Franz
English better every day ;-)
 Profile
Offline
 Post subject: Re: banjo-bolt-round-head
PostPosted: Sat Aug 04, 2018 9:26 pm
Franz, look carefully, it has two flats each side for a spanner, or it should have.Fr
_________________
 Profile
Offline
PostPosted: Sun Aug 05, 2018 7:45 am
ok
with picture it will be easy to see what i mean
the car is new for me, someone has done it like it is in the photo
it is wrong
the engine is a XPJMi
the bolt there is difficult to open, so i ask here
my pressure in the gauge is to low, it is about 35 psi
the line to the gauge is new, but it is at the head like it it in the photo
i want to change it to the block, but i don t know how to open
i will be carefull so i ask here
_________________
Best Regards
Franz
 Profile
Offline
PostPosted: Sun Aug 05, 2018 8:17 am
after i have written an idea come to my brain ;-)
i go to the garage and ....
i hope it will work
tomorrow i will order a new banjo bolt for the block
than we will see
_________________
Best Regards
Franz
 Profile
Offline
PostPosted: Wed Mar 13, 2019 9:08 am
Hi
so today , realy bad rain outside, i had time to do the oil line,
my special tool works perfect,
i took off the oil line to change the gauge line from the top to the bottom
in the past when they had done it they took wrong banjo bolt ?
the fine banjo bolt was at the bottom , it has the round head, so i need my special tool
i put it back at this place after turn around the line
at the top at the laystall head there was the other bolt, i think not the right one, i took it again , and hope it will go.
than i start the engine,
and
big surprise, the oil pressure was 35 before change the line, now 65
so it is realy important where the oil gauge line fit, it should be at the bottom
last year i was realy afraid ....
_________________
Best Regards
Franz
 Profile
Offline
PostPosted: Fri Mar 15, 2019 6:24 am
Yes, gauges read best when close to the source.
_________________
Mitch
1948 MG TC Special
1958 MGA
 Profile
Offline
PostPosted: Fri Mar 15, 2019 12:42 pm
Hi
now i know it,
but i have read a lot here and in one other forum, some people say it doesn t matter where it is.
I have the car driven 6 month, every time afraid i damage the engine,
is there sombody who knows the original thread of the banjo bolt for the laystal head. the bolt they used for my car isn t the right one. but in the moment it works, some day i will prepare the thread and take the right one.
a lot of little problems to solve before.
_________________
Best Regards
Franz
 Profile
Offline
PostPosted: Sat Mar 16, 2019 1:56 am
Hello Franz,
the original thread type in a cast irion head is metric M10 x 1 mm, so I guess the thread in a Laystall head is the same,
cheers Carl
 Profile
Offline
PostPosted: Sat Mar 16, 2019 3:37 am
Hi Franz, the end result is the oil pressure is still the same!
 Profile
Offline
PostPosted: Sat Mar 16, 2019 4:57 am
no
it isn t the same
before the turn around it was max 38
i was in the garage 10 minutes ago, done the last work before starting
now it goes up tu 80,
nothing done else, only change from the top to the bottom of the engine, to the original position
before i fit it again, i check the pipe, it s open for the oil, nothing damaged
_________________
Best Regards
Franz
 Profile
Offline
PostPosted: Sat Mar 16, 2019 9:19 am
The physical pressure will be the same, but indicated pressure will be higher and more true to actual pressure at the lower fitting.
_________________
 Profile
Who is online
Users browsing this forum: No registered users and 9 guests
Powered by phpBB
