best manual
- Rod Letcher
best manual
Rod
Rod
Rod
1913 Ford Model T Speedster
1938 MG TA
1952 Jaguar XK120 FHC
1957 Ford Thunderbird
1938 MG TA
Re: best manual
Re: best manual
Re: best manual
- Rod Letcher
Re: best manual
Rod
Rod
Rod
1938 MG TA
1938 MG TA
Re: best manual
- Rod Letcher
Re: best manual
Rod
1938 MG TA
1938 MG TA
Re: best manual
Rod,
Good luck and happy reading.
Bill - TA2190
Bill - TA2190
Re: best manual
Rod,
Actually the black book you have is not the Bentley they refer to. Here are links to the book. The green book (1st link) is a later edition of the book in the second link
https://www.amazon.com/MG-Workshop-Manu ... 0837617464
https://jollyrogersmotors.com/store/p/1 ... anual.html
The AUTOCROSS LTD. book is indeed a little light on TA info!
Bill
Bill
