What issues might I encounter if I try to use a 'Moss Motors" wheel cylinder meant for a TC on my TA?
Rod
wheel cylinder TA
- Rod Letcher
wheel cylinder TA
Rod
http://www.customfurniture.net/
1913 Ford Model T Speedster
1931 Ford Model A Deluxe Roadster
1938 MG TA
1952 Jaguar XK120 FHC
1957 Ford Thunderbird
1992 Chevy Silverado stepside PU (bought new)
1938 MG TA
Re: wheel cylinder TA
Slightly different part number on the NTG web site so I'm not sure.
If you're in the UK ring NTG 01473 406031 and ask Linda (or MIke).
Ed to add that I've just noticed where you are. Ring Doug Pelton at From the Frame UP
- Rod Letcher
Thanks for the response, I think I will send both front cylinders to "White Post Restorations' and not have to deal with cobbing some fittings/hoses together to make the "c" cylinders work. Anybody have any experience with "White post"
Rod
Rod
Rod
1938 MG TA
1938 MG TA
I've heard both good and bad reports about them. A wheel cylinder is such a simple item that I can't imagine anyone would have a problem sleeving it. Even a corner machine shop should be able to handle the job.
I would use Mark Frappier of Agawam, Massachusetts over anyone else. He does all my sleeving, and is EXCELLENT!
