TA Wiper Motor
ibertie
TA Wiper Motor
Post by ibertie » Thu Feb 20, 2020 2:38 am
Good morning All,
I have an issue with the wiper motor in which the motor does not want to rotate.
There is 12v supply to the motor and a supply at the switch breaker contact, however the motor will still not rotate.
I have cleaned all the contacts and checked the gearbox is not solidified with old grease, however electrics I am less knowledgeable with.
Any suggestions please
Ian
Best Regards
Ian Bertie
1936 TA0728 / XPAG B4181
Re: TA Wiper Motor
Post by Marv » Thu Feb 20, 2020 4:22 pm
If you have a shop nearby that does generators, alternators and starter motors, Take it to them, they can probably test it, Brown and Gammons may be a place you can send it as well.
Re: TA Wiper Motor
Post by frenchblatter » Fri Feb 21, 2020 12:05 am
Ian, I'll take a look on Saturday.
Re: TA Wiper Motor
Post by jddevel » Fri Feb 21, 2020 12:59 am
In the past I`ve found that with early type motors, wear in the armature bearings are suficient to jam it and prevent rotation. I assume you`ve "spun" it manually to ensure it`s free?
ibertie
Re: TA Wiper Motor
Post by ibertie » Fri Feb 21, 2020 9:20 am
Hi jddevel
Yes, everything moves freely, just not under it's own steam
Best Regards
Ian Bertie
ibertie
Re: TA Wiper Motor
Post by ibertie » Fri Feb 21, 2020 9:21 am
Thanks Norman
Best Regards
Ian Bertie
