TA map lamp
Bob Clarke526
TA map lamp
Post by Bob Clarke526 » Mon Mar 09, 2020 12:17 pm
Hi, two weeks to go and DDF 978 should be on the road after a six year rebuild, one small issue, how do I replace the bulb in the map light on the dash. Didn't check before I fitted it to the dash, and now
I need to get it fixed before I fit the under dash board, which was probably one of the easiest jobs on the rebuild. Many thanks Bob C
Re: TA map lamp
Post by Steve Simmons » Mon Mar 09, 2020 12:42 pm
The cover just pulls off. There are a couple detents at the base which keep it in place.
Bob Clarke526
Re: TA map lamp
Post by Bob Clarke526 » Thu Mar 12, 2020 11:20 am
Thanks Steve it worked. Bob
