TA body tub dimensions
Mike Armstrong
Post by Mike Armstrong » Wed Oct 02, 2013 8:52 am
I am about to embark on restoration of my early TA 0607.
I would be grateful for the following measurements :
- Rear Centre Panel early TA and late TA/TB
- Panel Assembly above rear axle early TA and late TA/TB
- Rear Prop Shaft cover - early & late (the panel over the propshaft behind the seats)
- Rear strengthener (like bullhorn) -early & late ( the width tip to tip )
Regarding the metal body/chassis side frame on which the body tub is mounted -
is there a difference in the early TA and the later TA (TB) - particularly as the early model has a
longer fuel tank and narrower mudguards?
Any help with these would be gratefully appreciated.
I have already got some wooden parts but don't know if they are for an early or a late car.
Thanks. Mike Armstrong Lisburn, N.Ireland
