Rebuilding TC5560
Herman 5560
Re: Rebuilding TC5560
Post by Herman 5560 » Wed Mar 20, 2019 9:26 am
Lots of 7/8” master cylinders but all only single action. Can one asume half the bore if one goes for a dual action cylinder. Surely half the volume will have to go to 2 slaves and half to the other 2. Could improve the feel of the brakes because the smaller the master the higher the pressure with the same force ????????
Post by Steve Simmons » Wed Mar 20, 2019 9:41 am
Smaller bore means more power but longer pedal travel. Two bores half the size should produce the same power as one bore, but you may run into proportioning issues since the front brakes do most of the stopping. So a metering valve might become necessary unless you figure out a custom bore size front versus rear. If it were me, I'd just fit an original and forget about it.
Herman 5560
Post by Herman 5560 » Wed Mar 20, 2019 10:17 am
Ok. Accepted. I need to get this car a runner
Herman 5560
Post by Herman 5560 » Wed Mar 20, 2019 9:31 pm
Just pulled off the leopard skin seat cover and found what I think must be the original seat cover.
A Red car was suppose to have Beige seats and it has 22 strips.
Pitty the wood is totally rotten, especially the lower bits, but it is a good template.
Herman 5560
Post by Herman 5560 » Thu Mar 21, 2019 4:59 am
So between load shedding and working on the harness and having power to use my grinder, this is my version of the Battery Positive Cable to starter motor clamp.
Pos Cable clamp.jpg (69.31 KiB) Viewed 5861 times
Now what is the correct routing, does the cable go to the side of the starter?
to the side.jpg (62.47 KiB) Viewed 5861 times
Or on top and behind the steering shaft?
On top.jpg (46.19 KiB) Viewed 5861 times
Herman 5560
Post by Herman 5560 » Sun Mar 24, 2019 1:38 am
No load shedding planned for today, but I only found that out this morning so already planned load shedding jobs like bending the 3mm ply to form the top of my seat base. Wet rag has been on the play since yesterday. Not sure I will get it to 100% follow the profile of the side planks, but giving it a good go.
Herman 5560
Post by Herman 5560 » Sun Mar 24, 2019 1:44 am
Almost feel sacroiliac to hide all those beautiful braided wires, but need to get the harness in before I fit the floor or the dash.
Post by Franz Tenbrock » Sun Mar 24, 2019 5:44 am
I have the same thing in front of me, but I will protect the individual circuits with fuse and relay
pity that the beautiful cables are then wrapped and you hardly see any of it
in the moment i read lucas section 6 vehicle wirinig circuits
translate it with google and my school english and make a word document from it in german ;-)
its easyer to understand it for me, learning english and learning vehicle wiring ;-)
Herman 5560
Post by Herman 5560 » Sun Mar 24, 2019 8:53 am
Post a link to it please.
I am also adding more fuses. Relays only to work the indicators/stop lights. I do not want to add indicators lights at the back so using the brake lights.
Post by Franz Tenbrock » Sun Mar 24, 2019 9:06 am
http://www.rjh-heritage.ch/index_htm_fi ... ervice.pdf
wonderful wheather here in germany, so i took a ride with my MG
i love it
wiring has a lot of time, next winter ?!
Herman 5560
Post by Herman 5560 » Sun Mar 24, 2019 8:17 pm
Thanks, very informative, especially page 11. That explains/show which wires has permanent power and which only once the ignition is turned on. :thumbs:
Post by Franz Tenbrock » Sun Mar 24, 2019 9:59 pm
i found this here
http://www.mg-tabc.org/resources/tech/
than i wrote an email to Rick Storms
and got it
THX Franz
Herman 5560
Post by Herman 5560 » Mon Mar 25, 2019 2:16 am
Great info, also the one on how the wiring behind the dash must look.
Will print all the pics and stick them together to form the whole dash in one.
:bow:
Herman 5560
Post by Herman 5560 » Fri Mar 29, 2019 9:34 am
starter brkts.jpg (83.19 KiB) Viewed 5779 times
Picked up the lazer cut brackets as per page 246 of TCFE.
Tomorrow debur and polish.
Post by Franz Tenbrock » Fri Mar 29, 2019 12:50 pm
you have a laser at home
Herman 5560
Post by Herman 5560 » Fri Mar 29, 2019 11:05 pm
Noooooo :cry:
I wish, but it is cheep enough to have it cut. I spend the week day evenings drawing up the parts and then pick them up about a week later, BUT...
I need to have some sizes.
Anybody had a chance to measure their bonnet striker/catch plates? ;)
Post by SteveW » Tue Apr 02, 2019 5:56 am
Hi Herman,
My bonnet strikers are still on my front wings which are buried deep in the roof space of my garage. I'll see if I get the chance to dig them out at the weekend and take some measurements. I'm fairly sure that they are the originals. Were you wanting the dimensions of the big seat back hinge and slot things or was that someone else?
Herman 5560
Post by Herman 5560 » Tue Apr 02, 2019 7:58 am
Nice to hear from you again.
Yes it was me. Fantastic if you can get to them.
Herman 5560
Post by Herman 5560 » Fri Apr 05, 2019 11:04 pm
So my car also had some funny reproductions for the seat Backres adjuster brackets that goes on the rear wheel arches.
Got this almost square on pic, so drew a 10 x 10 mm grid onto it and created my own CAD drawing for Mr Lazer cutter.
And this is what I got.
Now all tigged up and ready to go to the chromer with my grill.
Herman 5560
Post by Herman 5560 » Fri Apr 05, 2019 11:11 pm
Sorry lost the pic.
And YES i remembered to make a Lh and a Rh part. :P
