Post new topic Reply to topic  [ 4 posts ]
Author Message
Offline
 Post subject: non start when hot.
PostPosted: Tue Jun 11, 2019 4:00 pm
Came back from a long run Sunday (About 45 miles) in TC 7440 and backed into the driveway, shut the car off to open the garage door and empty the car of jackets and other gear. Got back in the car and it would not start. Pushed it into the garage and tried again, nothing. About fifteen minutes later it started right . Coil is about 5-6 years old and it was quite warm (83 deg.) Anyone have any ideas???? Thanx
 Profile
Offline
 Post subject: Re: non start when hot.
PostPosted: Tue Jun 11, 2019 7:01 pm
Vapor lock would be first guess.....
 Profile
Offline
PostPosted: Wed Jun 12, 2019 1:38 am
I'll second that. I think I solved the problem by fitteng the plastic heat blocks as fitted to the MGB. I've had a vapour lock problem and, when we lived in France, often drove in 30+c temps. Could switch off, pop into a shop and it would always start again.
Actually I fitted the heat blocks to stop the carb flanges warping, which is caused by heat, not overtightening the nuts.
_________________
 Profile
Offline
PostPosted: Wed Jun 12, 2019 8:45 am
Heat soak vapor lock. Next time it will not hot start try using the choke to start. If that works, you do not need any modifications.
 Profile
Who is online
Users browsing this forum: Google [Bot] and 19 guests
Powered by phpBB
