Did any TC Have a Brass Body Fuel Pump?
Posted: Mon Feb 09, 2015 5:54 am
by Julian Evers
Dear All
Did any TC leave the factory with a brass bodied fuel pump (AUA25)?
Best regards
Re: Did any TC Have a Brass Body Fuel Pump?
Posted: Mon Feb 09, 2015 9:31 am
by Phil Dadd
Hi Julian,
I can't give an authoritative answer, but to my knowledge the last T Types to be fitted with brass fuel or carburettor components were 1936 or 1937 TA's. A friend of mine has a narrow winged 1937 car (the same rear guards as a P Type) and this is fitted with brass bodied carburettors. I can't help with the numbers as I have not seen him or the car for many years. He also has a later model TA with the same rear guards as the TC, and this has alloy components the same as on my car.
Phil TA 2982
Posted: Mon Feb 09, 2015 4:21 pm
by Gene Gillam
According to Moss Motors the TC had them up to serial 4000. Moss sells them now: http://www.mossmotors.com/Shop/ViewProd ... exID=29523
Posted: Mon Feb 09, 2015 11:58 pm
by dirk w dondorp
mine has one- TC0660- 1946, but that is no answer to the question if it was already there when the car left the works......
Dirk
Posted: Tue Feb 10, 2015 12:08 am
by Julian Evers
Doing a little research, Michael Sherrell states that the brass body continued on into the early TCs. Can this be narrowed down a little more from Circa chassis 4000 and 'early'? I must declare an interest, I need to buy a new pump and my car is TC3382!
Best regards
Julian
Posted: Tue Feb 10, 2015 3:42 am
by Phil Dadd
Julian, on page 60 of Mike's book he states that the brass base changed to alloy around TC4407.
Sorry I misread your post. I was referring to the bodies of the carburettors themselves. these were common on TA's as I have already mentioned.
Regards,
Phil TA 2982
Posted: Tue Feb 10, 2015 4:39 am
by Julian Evers
Dear Phil
'Twas I mixing bases and bodies. Many thanks, brass base it is.
Best regards
Julian
