Replacing Blown Head Gasket
I have been dealing with overheating on my 1948 MGTC. I’ve reset the mixture, the timing, had the radiator flow tested, installed an MGB 7 blade fan, and replaced the water pump. I pulled the head and found evidence of a blown head gasket between cylinders 2 and 3.
My question is when I replace the head gasket should I use a copper gasket dressing or install the new gasket dry? Also after installing the new gasket and torquing the head, how much time should I run the engine before retorquing? When retorquing should I just check the torque on the head nuts, or should they be slightly loosened and then retorqed?
Thank you,
Paul Mascuch
Thank you,
Paul Mascuch
Re: Replacing Blown Head Gasket
There will likely be varying responses on this but here's my preference...
I use the standard County gaskets (original style) as sold by most suppliers and I do not use any dressing. They have some kind of coating on them already. I try to not touch the coating with my hands. The head and block are scrupulously cleaned with brake cleaner before installation.
I normally go about 200 miles before re-torquing. When I do, I loosen the nut about 1/8 turn and then take it up to spec. Then I move to the next nut.
Others have their own preferred methods but this has worked for me. So far I've never blown a gasket on my TC. Compression is about 9.1:1.
I hope this fixes your overheating issue. I would definitely think about having the head checked for flatness since it blew, especially if it blew because of overheating.
WKF Wood says nothing is needed on the gasket. Top of page II-11 or page 17. http://www.ttalk.info/WKF-Wood-XPAG-Engine-Book.pdf
I recently used nothing. You definitely do need to check your head for flatness. The reason the gasket often blows between 2 and 3 is because on these engines the head wants to deform upwards towards the middle.
Almost ANY technique is better than the usual torque-and-you're-done method. First, consider possible causes: the wrong torque is used, the block is not flat, the head is not flat, the head studs are stretched.
First, remove the head studs and check their condition - most are stretched or gouged. Screw on a head nut, and if you feel resistance, the stud is stretched - you can often see a waist in the threads. If the stud is stretched you will NEVER get accurate torque, and the studs must be replaced. I then run a small circular whetstone all around the deck surface to remove the high-spots where the threads have pulled up slightly. Checking the block flatness in situ is done with a really straight straight-edge and a .001 feeler gauge. Put the feeler gauge under the straight-edge and see if you can pull it out; check all over the head, and if you can easily pull it out the engine needs to come out and be re-surfaced. Do the same with the head, which is more likely to warp.
If I use an NOS gasket I lightly use Copper Coat seal on both sides; as Steve says above, new gaskets already have some coating. I put it all together and torque the head cold to 30, 40 and then 50 foot pounds with the original studs, or 60 with my replacement studs. I then put the rocker gear back on, and adjust the valves slightly loose, say .015". I then start the engine and make sure all is well, blipping the throttle a few times. I cool it all the way down and then use a 19/32" socket to loosen the nuts 1/4 turn in sequence, and then re-torque to spec, one at a time. (The 19/32" socket allows you to re-toraue without removing the rocker gear each time - just remove the clips for the end nuts.) I then take the car out for a test run, let cool and toraue again. After 50, 100, and 500 miles I do it again - always cold - and have, like Steve, never blown a head gasket.
Stretched head studs are the most common cause of blown head gaskets - see mgtrepair.net for my improved head studs.
I'm curious why I sometimes see people mention the difficulty of getting to the head nuts. Is it because of the replacement 12-point nuts? I've never had an issue. I use a 3" extension and a regular socket and it fits right onto all of them.
I also agree with Tom about torquing in several steps. I feel this is critical to success.
Steve - my "regular" Whit sockets are too tall, and I found a 19/32" socket at the Tool Barn to cut down, for $1. It's now a dedicated socket!
