machining the TC oil pump
- Norman Golm
I need to surface of the oil pump housing, cover and gears. I have had the parts to three shops and they don't seem to know how to hold the parts on a surface grinder. The surfaces are too rough to use the glass and sandpaper method. Is there another way of surfacing these parts? Or is there someone I can send the parts to?
Re: machining the TC oil pump
Have you tried a machine shop with a milling machine. It will get the surface perfectly flat and then you could do the glass and emery trick.
Stan
Stan
Send them to Butch Taras. He rebuilds pumps and does it properly. Uses a surface grinder and gets everything to proper clearance.
Roland “Butch” Taras
3733 Fourth Ave.
Glendale, CA. 91214
USA
Telephone / Fax +1 818-249-9031
mgyowner@yahoo.com
3733 Fourth Ave.
Glendale, CA. 91214
USA
mgyowner@yahoo.com
- Norman Golm
Finally found a journey men tool maker and had it done right.
