wheel cylinder TA
Rod Letcher
wheel cylinder TA
Post by Rod Letcher » Sun Oct 13, 2019 9:04 am
What issues might I encounter if I try to use a 'Moss Motors" wheel cylinder meant for a TC on my TA?
Rod
Rod
http://www.customfurniture.net/
1913 Ford Model T Speedster
1931 Ford Model A Deluxe Roadster
1938 MG TA
1952 Jaguar XK120 FHC
1957 Ford Thunderbird
1992 Chevy Silverado stepside PU (bought new)
Re: wheel cylinder TA
Post by frenchblatter » Sun Oct 13, 2019 2:07 pm
Slightly different part number on the NTG web site so I'm not sure.
If you're in the UK ring NTG 01473 406031 and ask Linda (or MIke).
Ed to add that I've just noticed where you are. Ring Doug Pelton at From the Frame UP
Rod Letcher
Post by Rod Letcher » Mon Oct 14, 2019 2:32 pm
Thanks for the response, I think I will send both front cylinders to "White Post Restorations' and not have to deal with cobbing some fittings/hoses together to make the "c" cylinders work. Anybody have any experience with "White post"
Rod
Rod
1938 MG TA
Post by Steve Simmons » Mon Oct 14, 2019 4:49 pm
I've heard both good and bad reports about them. A wheel cylinder is such a simple item that I can't imagine anyone would have a problem sleeving it. Even a corner machine shop should be able to handle the job.
Post by Tom Lange, MGT Repair » Mon Oct 14, 2019 6:01 pm
I would use Mark Frappier of Agawam, Massachusetts over anyone else. He does all my sleeving, and is EXCELLENT!
