windshield glass
jagman2
windshield glass
Post by jagman2 » Sun Aug 28, 2022 5:49 am
couls someone guide me as to what the correct size is to have windshield
glass cut for my TC?
thanks
cheers
Re: windshield glass
Post by Steve Simmons » Sun Aug 28, 2022 8:34 am
I've seen reference to 0.29" and 6.6mm as being original thickness. The only important thing is to get the overall thickness of glass plus glazing correct. I believe the channel is around 3/8".
Post by bloodysalmon » Sun Aug 28, 2022 8:42 am
TC windscreen glass - I am positive that the original laminated glass was not measured metrically but was of imperial size.
What I have ascertained in the past few years is that you are unlikely to find nor have made a windscreen in imperial size.
The nearest size i have made (20+ winsdscreens now) is 6mm glass, both either toughened and or laminated.
I have 4 new laminated screens being made. :thumbs:
Post by jddevel » Sun Aug 28, 2022 9:20 am
I have PM`d you requesting your location.
Post by jddevel » Mon Aug 29, 2022 12:12 am
I had PM`d you requesting location as I`ve an original admittedly cracked but out of the frame which I had a glazier replicate. It is important to note that the area around the wiper motor is cut to allow motor fixings. You did reply but gave no location which may have allowed a collection/delivery of my screen to assist.
jagman2
Post by jagman2 » Mon Aug 29, 2022 3:52 am
sorry for the delay. had an issue that needed attention. i am located in venice fl.
Post by jddevel » Tue Aug 30, 2022 11:28 pm
Being in the UK I can`t economically provide an original taken from a 1948 vehicle however it should be noted that glass has to be cut to accommodate the wiper motor fittings.
Post by bloodysalmon » Wed Aug 31, 2022 11:39 am
please be very aware that the glass doesnt just have the cutouts for the wiper motor, as there is the idle too, along with each corner having reduced cuts to cater for the 90 degree screw fixing plates ... so not just the wiper motor. I have the template as mentioned
