Voltage regulator issues
timandgerda
Post by timandgerda » Sat Apr 05, 2025 2:58 pm
Hi all.
My TC voltage regulator has packed up and I have decided to install an electronic one that fits inside the original casing. The wiring is fairly straight forward with one wire to the dynamo frame, one to the D terminal an earth and power supply. My issue is that I have had to remove both coils and the resistor at the rear to instal it and this seems to leave cable 37 (brown with white) from the ammeter with nowhere to go. Has anyone installed one of these and if so how did you wire up the ammeter?
Any advice gratefully received!
Cheers
Tim
BCBryan
Re: Voltage regulator issues
Post by BCBryan » Sun Apr 06, 2025 8:32 am
If you are doing this ourself, I'd be interested to know who supplied the parts you are installing? The complete units are bit pricey in North America.
Thanks, Bryan.
Will
Post by Will » Sun Apr 06, 2025 7:49 pm
Bryan,
Check out these gents in the UK. Satisfied with my dealings with them.
https://www.dynamoregulatorconversions.com/
timandgerda
Post by timandgerda » Mon Apr 07, 2025 2:47 am
I used electrodynamicsolutions - UK based. Excellent communications from the supplier regarding any queries. I bridged the two left hand side terminals (on the rear of the unit so nothing visible) to allow power to the unit and now the dynamo is charging well :thumbs:
cdrolshagen
Post by cdrolshagen » Tue Apr 08, 2025 6:50 am
Hi fitted several electronic regulator in a original housing,
all work well
cheers Carl
cdrolshagen
Post by cdrolshagen » Tue Apr 08, 2025 6:51 am
here one more
Post by Ray White » Thu Apr 17, 2025 1:33 am
The skill and brains of some forum contributors is truly remarkable. !! :thumbs:
timandgerda
Post by timandgerda » Thu Apr 17, 2025 11:32 am
I managed to apply some common sense and worked it out. Was very please with myself and then saw the posts from everyone showing me how to do it and that they had all been there before. :lol:
Reassuring to see that I did it properly though - thanks all :thumbs:
