What all holds the inner dash in place? I am particularly interested in the underdash metal braces that my TB is probably missing.
Tim Bloomfield
TB0613
Humid Louisiana
TB Inner Dash Mounting
- Tim Jackson
Re: TB Inner Dash Mounting
Another angle for a TC. Zoom in to see the two supporting brackets and fastener positions
1946 TC0999 / XPAG 1638
restore note
restore note
- ferricsteed
Thank you Tim and Carl. I am missing these two brackets. It looks like a slotted screw goes through the inner dash and through the metal bracket and held in place with a nut. The other end of the bracket fastens up to the bulkhead is less obvious. It looks like it could simply have two slotted wood screws for each bracket or it could be bolted with the through bolts that hold the scuttle to the bulkhead. Would you let me know. Excellent pictures by the way.
Regards,
Tim Bloomfield
TB0613
Louisiana
Regards,
Tim Bloomfield
TB0613
Louisiana
Hi Tim,
the brackets are not bolted to one of the bulkhead bolts,
attaches a picture you can spot the bracket bolts, all bolts are countersunk slotted 5/16 BSF
cheers Carl
cheers Carl
