TC front hub assemby with taper roller bearings - for amateurs
JohnHWSteedman@aol.com
Post by JohnHWSteedman@aol.com » Mon Feb 28, 2000 6:17 am
I recently asked about the correct sequence of assembling the front hubs of a TC. I was overwhelmed by the advice given and especially thank Messrs. Grunau, Old, Pleitner. McCrary, Furneaux for their insights. Having completed the assembly, I thought it might be worthwhile to record my progress step-by-step from the perspective of a rank amateur with only basic handtools.
1. I decided to use taper roller bearings rather tha ball bearings. These were purchased from Roger Furneaux's "Mad Metrics" as were new hubs ( the splines on my originals being well worn and I am determined to rid myself of the dreaded front wheel "clunks").
2. Stub axles were professionally crack tested and passed OK. Axle dimensions measured by my 1" micrometer showed almost no wear compared to the dimensions listed in TCs -Forever, page 103.
3. As many of the correspondents pointed out, the key to the success of assembly is that the central "core" (inner oil seal tapered washer,inside of inner bearing, original spacer, shims, inside of outer bearing, cupped drilled washer, nut) should form a solid, stressed surround to the stub axle, WITHOUT that stress being applied to the taper bearings via their outer sides. This means that shims that match the "central core" to the hub must be exactly tailored to your own components and their wear.
4. With a couple of extremely frustrating exceptions, assembly proved reasonably simple and accomplished with minimal (many thanks Don Spurr!) technical support.
As follows:-
5. Bolt stub axle to back plate and secure using the appropriate special lock washers. This enables the assembly to be firmly mounted in the bench vice, using fibre protectors on the vice faces.
6. I measured up the inner and outer bearings to determine the offset between the inner and outer rings. I did this by placing the bearings on a sheet of glass and measuring the difference, which amounted to 0.053" and 0.054" for each.
7. Based on this I had made two 0.100" washer shims with inner diameter 0.800" and outer 1.100" to match the original spacer.
8. I pushed the outer part of both bearings into the inside and outside of the hub, securing with Loctite. I used the old bearing as a drift and pressed home home with a matching (to the outside of the old bearing) socket set. - Very satisfying; Roger's components were a superb fit.
9. I purchased a shim sheet set from my local engineering supplies store. Through trial and error I discovered that adequate shims to match the spacers can be made using tinsnips (outside) and ,surprisingly for the inside cut out, a (cheap!) PAPER hole punch on shims up to 0.010".
Now the frustrating part!
10. Mount the stub axle in the vice, (leave out the inner oil-seal for the moment). Push on to the stub axle the inner oil seal cupped washer, inside of inner bearing, hub. Then from the front, mount he original spacer, 0.1" spacer, shims, inside of outer bearing, cupped washer and castellated nut. This operation has to be repeated many times until the shims added enable the stub axle nut to be tightened firmly (I'm sure there is an appropriate torque setting) and at the same time there is absolutely no "play" between the hub and the stub axle. In fact there should be sufficient load on the bearing that resistance to free motion has just been reached. Roger Furneaux tells me that this is the point where the hub requires 3 lb-inches torque to rotate it. I'll leave it to you to work out a suitable test rig to produce this - my wife wants to know where her scale weights disappear to.
In my case I needed shims of 8 "thou" on one side and had to grind down the new 0.100 spacer by 5 "thou" on the other side. Which meant, I assume,that the original spacer was slighly long(?) to begin with.
11. Grind down the nuts, so that the torque is correct and the castellations enable the split pins to be inserted.
12. Final assembly:- Pack the bearings with grease, add the inner oil seal, repeat 10, - hopefully for the last time and insert the split pin.
Comments welcomed.
John Steedman TC0301
Post by JohnHWSteedman@aol.com » Tue Feb 29, 2000 2:46 am
As follows:-
bearing, hub.
Comments welcomed.
